Re: IH184 engine rebuild query
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by jakee on March 22, 2000 at 19:33:27 from (205.188.193.53):
In Reply to: IH184 engine rebuild query posted by MIKE on March 22, 2000 at 09:12:04:
no actully your machine shop is wrong . aluminum gets rid of heat faster then iron. and the pistons will not melt(belive me)things that burn pistons are to mutch timing and a lean condition.pistons are match ballenced in a set of 4 like for your motorso there close,just the pistons,then the rod is balanced big end and small end then theres a formule to carry over for the crank,unless its externally balanced,some one out there help with this?i forget how you carry the weight to do the crank balance,and it,s all done in grams.
Post A Followup
: Re: Re: IH184 engine rebuild query
