Posted by Owen Aaland on September 13, 2008 at 02:18:45 from (65.161.86.22):
In Reply to: 2444 hydraulics posted by rlaporta on September 12, 2008 at 10:33:57:
The plug on the right rear corner behind the seat is for the hydraulics unless you have a front mounted, crankshaft driven pump. Then there is a common reservoir with the transmission and rear housing. The front pump draws oil from the rear end and passes it through an external filter on the way to the pump. The return from that systems enters the normal hydraulic reservoir and then overflows to return to the rear housing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
