Re: line that goes to air breather to engine
Posted by Farmall JD on September 13, 2008 at 07:16:51 from (24.137.36.116):
In Reply to: line that goes to air breather to engine posted by Brownie 450 on September 13, 2008 at 06:37:26:
ryanroth said: (quoted from post at 19:37:26 09/13/08) Hello everyone--
Need to know what exactly went from the engine to the air breather on a 44 H. Trying to find replacement. It was not there at all when I bought the tractor. Thanks Ryan
Its a steel pipe that goes from the back of the head through the gauge mount to the breather. Check out a tractor scrap yard in your area they might have one.. If not you should be able to make one with modern fittings. It's not period correct but its under the hood so you will be the only one to know.. But that is if you don't mind..
