Re: Farmall B mag- install??
Posted by Bob on September 14, 2008 at 10:36:08 from (69.178.228.68):
In Reply to: Farmall B mag- install?? posted by RustedRedWill on September 14, 2008 at 10:31:02:
Note where the rotor is pointing on the mag now installed, and where in the adjustment slots the mag is located.
Turn the new mag so the rotor is in the same position and swap it in place, and set the timing the same.
That should get you REAL close.
However, it's a good idea to verify the impulse trips @ TDC, ESPECIALLY if hand-cranking the engine.
