Posted by Centrall Illinois on September 14, 2008 at 15:58:46 from (75.105.128.38):
In Reply to: Engine hours posted by Pat B in Mich on September 14, 2008 at 15:45:38:
That is kind of a loaded question. It depends on what your intentions for the tractor are, what the tractor is, and how particular you are. Around central Illinois most tractors used in the field have up to 4500 hrs on them before they get traded. I have also seen 12000 hour tractors being used every day. One mans junk is another mans treasure. I know if you get away from here the hours go up considerably. Are you going to be keeping the tractor long term or do you think it will be traded in in the future. If that is the case you have to think about future trade in value. A diesel engine as well as a gas engine should last a long time before overhaul. I have overhauled engines anywhere from 300-1200 hrs. The newer engines seem to last longer before needing anything major. Usually the more hours and the older the tractor the more chance of repair. Your mileage may vary.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
