Posted by rustred on September 14, 2008 at 17:02:55 from (209.115.232.65):
In Reply to: Super W4 carb issue posted by Bubbar. on September 14, 2008 at 15:12:54:
have you checked the float for heavyness, could be a pin hole in it.what is the adjustments set at?main adj.-2to 2.5 turns out, idle mixture-1to1.5 turns out. this makes it run pretty dam good and can fine tune later.you didnt say how its briefly running, like flooding i would presume. is the governor in its correct slot? is it ok? you said the tractor was raceing, need to find out why.this should be a start with the info.that you gave.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
