Re: Super W4 carb issue
Posted by Bubbar. on September 14, 2008 at 17:35:02 from (70.49.242.236):
In Reply to: Super W4 carb issue posted by Bubbar. on September 14, 2008 at 15:12:54:
It ran smooth at an idle for a few seconds. No smoking that I could see. When I attempted to advance the throttle, it stalled and it was down hill after that. Governor is in the correct slot, main jet set at 3 turns, idle jet at 1 turn for first start according to directions. Tried other variations of settings. Nothing worked. Compared governor to the one on my H, everything looks good.
If the float was the problem, then I don"t understand the excess fuel only while cranking.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
