Posted by JimB2 on September 14, 2008 at 17:52:08 from (99.241.179.24):
In Reply to: 574 Questions posted by Drtravis on September 11, 2008 at 15:06:50:
Hi Travis, never worked on a 574 gas only Diesel models. Re parking brake, check for broken cable, usually breaks at stud at side of transmission case, properly adjusted parking brake and lastly if all the above doesn't fix it then probably someone has driven tractor with parking brake engaged and chewed up the parking brake band in the range transmission under the seat. My brother's IH mechanic says usually to do a proper job the brake drum and band both have to be replaced. This is many $$ in labour as fenders, fuel tank, 3pt housing have to be removed. Some mechanics do a cheaper job of replacing band only in thru the inspection plate under right foot rest.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
