Re: Hey old F-20!
Posted by James Williams on September 14, 2008 at 19:14:26 from (74.46.214.232):
In Reply to: Hey old F-20! posted by Marjorie Van Fossen on September 14, 2008 at 08:20:54:
Marjorie,I beleive you have a rod bearing with a lot of play in it,use your inspection hole to check for any excessive play in your bearings.Plastic gage is a good way of checking clearence but plastic gage wasnt around when these motors were built.check the side to side play of your rod bearings they should be just snug enought you can tap then side to side with a small tac hammer,if you can slide them with your hand or move them up and down with your hand there to loose,if your carefull you can remove shims through the inspection holes.if all of your rods need adjusting you will be better off to remove your oil pan.these tractors were designed to remove the pistons and change the rings through the inspection holes
jimmy
