The trans & rear end are using the same fluid--tractor came from the factory with 90 wt. gear lube. Any shop work done on these --- the dealer put in Hy-tran to replace the 90 wt. The engine on our diesel takes 10 quarts. Don't know about the gas model, but our MTA takes 10 quarts also. The filters---we use IH filters on ours. The cost is slightly higher, but worth the extra. Some people use other make filters & get by. Check & clean the hydraulic box screen found at the bottom of the box on the right side. Four bolts & the screen should come out.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
