Posted by Brownie 450 on September 15, 2008 at 03:56:51 from (216.51.158.151):
In Reply to: SMTA Lift-All posted by GordoSD on September 14, 2008 at 15:22:42:
On our MTA, to use the loader, you have to have the "remote cylinder" valve locked in the forward position. To use the remote valve for trailing implements,the "loader" valve lever has to be locked in the "raise" position. Sounds like you might have a loose flywheel. You might check the bolts on that or pressure plate bolts. Alternatively, check for worn bearings/ shafts at the clutch/ TA input shafts going into the trans. Something is doing a dance number in there to get vibration like you are talking about. Better find what is causing it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
