Re: PTO Seasonal Disconnect.
Posted by Owen Aaland on September 15, 2008 at 17:23:21 from (65.161.86.22):
In Reply to: PTO Seasonal Disconnect. posted by Wayne from MN on September 15, 2008 at 09:15:58:
Wayne from MN said: (quoted from post at 09:15:58 09/15/08) That is a dry cavity; you have a seal leaking somewhere. Some (maybe a lot) dis-assembly required!!
It is a dry cavity only if there is no oil left in the transmission. :wink: The lower shaft in the clutch housing runs in oil all the way from the front to the rear. That is how the oil gets to the PTO gears and bearings in the front of the clutch housing.
There should be a blind hole the bolt to thread into. Most likely someone has installed too long a bolt at sometime and broken the the top off the hole exposing it to the oil reservoir.
