Re: 656 or 560
Posted by Owen Aaland on September 15, 2008 at 17:36:04 from (65.161.86.22):
In Reply to: 656 or 560 posted by Steven f/AZ on September 15, 2008 at 17:19:02:
Steven f/AZ said: (quoted from post at 17:19:02 09/15/08)
Hugh MacKay said: (quoted from post at 16:05:32 09/15/08)
Put the gasser back in the 560, then sell it to someone that only wants to look at it.
Best idea I've heard of in months!!
There will be lot of problems swapping the two engines. The front of the engines mount different between the 560 and the 656 so you would need different covers for both of them. The exhaust pipes are on different sides of the hood, gas on right, diesel on left. The engine controls and air filter tubing will not interchange.
The 560 has a heavier clutch housing and rear frame. It followed the M line. The 656 followed the H line. The 460 was the first of the H line to have a 20 inch width across the front frames like the M has but the clutch housing and rear frame are still narrower.
