Re: HOW DO YOU SET H IGNITION TIMING
Posted by TomH in PA on September 15, 2008 at 18:06:00 from (67.142.130.19):
In Reply to: HOW DO YOU SET H IGNITION TIMING posted by RANDY DAUGHERTY on September 15, 2008 at 12:41:06:
Tighten both screws all the way in, the back the idle out 1 1/2 turns and the main (bottom screw) 3 turns.
There are a pair of timing marks on the fan belt pulley and a pointer on the right side, just in front of the governor. To get in the ballpark on timing, make sure #1 cylinder is on the compression stroke, then turn the engine slowly until the points just open (the rotor should be pointing to the #1 wire). The timing pointer should be close to the first mark as it's coming over the top of the pulley; adjust the distributor as needed to have it break when the mark is close to the pointer.
