Posted by f20inmi on September 15, 2008 at 18:48:26 from (97.115.164.179):
In Reply to: Re: F-20 miss on #2 posted by bdunegan on September 15, 2008 at 15:11:34:
Heavens. Don't give up that easy.
If you checked your valve clearances on number 2 and the valve operates freely, you have a spark problem. You tried new plugs and new wires and they will spark everywhere except 2. That leaves something in the mag. Now all the other plugs are firing, so you have spark to the distributor gear. From here, I would say that it's in the cap. Any buddies have a spare?
I took my mag a part four times this spring before it would start. Finally ran it on the bench with a cordless drill before it would fire consisitently.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
