Posted by John A. on September 15, 2008 at 21:23:24 from (138.210.118.138):
In Reply to: '59 Farmall 560 LP posted by Reagan Stephens on September 15, 2008 at 16:49:45:
Reagan, A lot of things need to happen beside what you mentioned. Wires, points, condensor, Plugs, gap settings. Now the tank needs a shot of lp, if there is none left in the tank after all the yrs. attempt a fill like described above or just run a rubber hose from an old style tank to the Vaporizer. Shoot a little oil in each cylinder to lube up the rings and not try a dry start after all these yrs. To Start, Leave the Liquid and Vapor Valves Closed.start turning the engine over to start, then just crack open the vapor valve. if she starts, good. if not check to see if you are getting fire, etc, etc, etc. If you have questions feel free to call me and lets visit about it. My # is 512-577-3837. Hope this helps. Later, John A.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
