If the oil is dripping out around the seam where the cup attaches to the air cleaner, then you need a new air cleaner housing or a new cup. One or the other is bent and not sealing tightly as it should.
The oil gets sucked up into the steel wool inside the air cleaner and grabs on to the dirt as it goes by. Normally there is no place for it to leak.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
