Posted by Paul in MN on September 16, 2008 at 08:30:13 from (71.210.136.141):
In Reply to: Get the rod out? posted by Mac DeBusk on September 16, 2008 at 04:46:00:
Mac,
Press the clutch pedal down to disengage the tranny, then put a pry bar inside the block and lever against the crankshaft throw for #2. As the crank is now straight up it is in the best position for this method to work. Pry the crank away from the jammed rod #1. Maybe there is room to put a wood block inside of the block wall so you are spreading out the forces from the end of the pry bar.
I'm trying to remember whether you can access the flywheel from the bottom (like a car often has a removable sheet metal cover under the flywheel). If so, you could pry on the flywheel, but use a piece of oak, not the metal prybar, if you are pulling against the ring gear teeth. Learned that the hard way.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
