Posted by Janicholson on September 16, 2008 at 10:51:03 from (199.17.6.128):
In Reply to: Farmall A Getting Hot posted by astimpson1 on September 16, 2008 at 09:30:53:
If the radiator core tubes are scaled up with deposits, it will act like that. Look in the radiator (with enough coolant out that you can see the tops of the cores. If they look a bit plugged, it is time to test it for flow. Take out all coolant. Remove the bottom hose at radiator. Get a five gallon clean bucket filled with water. Begin pouring in water into the cap opening about as fast as you can pour it without spilling a bunch. If it backs up and takes it slowly and does not run out the bottom freely. it is plugged. 2 or three gallons a minute is minimumish. If plugged, try a real rad flush product to see if it helps (follow all directions to a T. If still no help, it needs to be cleaned by a Rad shop. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
