Re: Farmall H leak
Posted by Janicholson on September 16, 2008 at 13:45:58 from (199.17.6.128):
In Reply to: Farmall H leak posted by labman98 on September 16, 2008 at 13:19:45:
IT is a plain fiber gasket, not O ring. The first isue is to tighten the bolts evenly all around to see if the fixes it (usually makes it way better, or fixed)
Next is to drain the differential loosten the bolts and (with no strain on the housing, proper blocking so it cannot fall and break off the axle) slide the axle housing away (Not much, it will not go far) Then scrape all the old gasket out, and put a new gasket in by cutting it at the top, taking out the bolts, and wrapping it around (with a thin film of #2 non hardening permatex applied to both sides of the gasket, and a bit more where the split is located) then retorquing the bolts. Good luck, JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
