Posted by JimB2 on September 16, 2008 at 15:02:59 from (99.241.179.24):
In Reply to: IH 674 loader posted by Jason from MI on September 16, 2008 at 11:21:45:
Hi Jason, as others have said check parking brake. If it has a T/A, a couple checks, go up and down hill in LO T/A make sure it doesn't free wheel going down hill, next on a down hill slope with TA in HI and transmission in 3rd LO shut engine off with clutch released, release brakes and see if engine will hold tractor. If tractor rolls forward without engine turning then HI side of T/A is weak.
Re loader, models 1550, 1850 and 2250 will fit 674. If loader has double acting cylinders, check hydraulics by lifting front end of tractor off the ground with down pressure on loader. Should lift front end easily.
If it is D-239 Diesel engine it should last a long time if proper Diesel grade engine oil and changed regularly. Pull out crankcase dip stick, check for over full and smell oil for Diesel smell. Checking for front lip seal on Bosch injection pump leaking Diesel into crankcase. Seal is only $8.00 but have to remove injection pump to replace. The seals wear out now because of low sulphur Diesel fuel not supplying sufficient lubrication. So if you buy this tractor either add some Diesel fuel conditioner or a couple table spoons of engine oil every time you fill the tractors fuel tank.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
