Posted by Hugh MacKay on September 16, 2008 at 16:55:59 from (209.226.247.13):
In Reply to: Re: 656 or 560 posted by Lee in Iowa on September 16, 2008 at 06:12:13:
Lee: Every 5 or 5 & 2 speed Farmall that ever had a loader for very long got stuck in two gears. Quite common for a loader tractor to shift 50 times for every shift of a deawbar tractor. If your going to use gear shift lever and those shift rails, they do wear out. Another reason they are a poor loader tractor.
My 300 had a loader most of it's 20,000 hours, gear shift lever rebuilt 6 times. My 560 probably did 2,500 hours loader time and had shift lever rebuilt once in 11,000 hours. My 656 probably saw less than 200 hours of loader work and never locked up in 15,000 hours. I did replace the pin on shift lever shaft but not the shaft.
Some day your working your tractor, count the shifts per hour doing loader work, then count shifts per hour disking or baling, etc. My 1066 never had the shift mechanism rebuilt in 15,000 hours, never had a loader. I've seen it work 24 hours on the clock, probably went to neutral dozen times, 4 speed never shifted and TA maybe 50 times. That doesn't wear out shift linkage very fast. Compare that to a loader tractor that probably gets shifted 100 times per hour.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
