Re: 6-volt
Posted by Clarkbug on September 16, 2008 at 19:22:25 from (72.66.50.236):
In Reply to: 6-volt posted by tbinny on September 16, 2008 at 16:32:21:
I ran into a similar problem on my H recently.
Does the Ammeter deflect to the negative side while running by chance? (I honestly dont know if the 300u has one, but I figured its a safe bet)
Apparently the starter doesnt care about the grounding, and as long as the generator has been repolarized to the correct ground, it will work and charge things just fine as well. Also, your ignition coil should have the wires switched if you intend to run with the negative vs. positive ground.
I switched mine back to positive ground after repolarizing the generator and it is running well.
If you do a search on the positive vs. negative ground, you should find that post thats about three weeks old.
