Re: Farmall C Generator.
Posted by John T on September 16, 2008 at 19:28:37 from (66.244.97.31):
In Reply to: Farmall C Generator. posted by EDW on September 16, 2008 at 17:26:41:
EDW, Put that volt meter on the battery and when shes setting the voltage ought to be 6.3 volts if a 6 volt and 12.6 if a 12 volt. Then start it and run it at high RPM and iffffffffffff shes charging the battery voltage should rise, 6.5 to 7 or so if a 6 volt and 13 to 14 or so if a 12 volt. If it does that its charging, if not its NOT.
To see if the non charging is due to a bad genny or a bad Voltage Regulator see Para 5 in my Troubleshooting Procedure.
Heres a URL Link for my Troubleshooting for non charging
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=665110
John T
