Re: M vibration
Posted by Janicholson on September 16, 2008 at 20:54:12 from (66.173.50.8):
In Reply to: M vibration posted by ckfarmall on September 16, 2008 at 15:37:49:
I vote for an issue with the Pressure plate in the clutch assembly. (the fan pulley needs to be replaced, buy a good one and study it, then (reading the manual) replace the broken one)
A bent or broken fan blade will cause the vibes, but that is pretty obvious.
The clutch can be removed out the bottom WO splitting the tractor. If you remove the clutch assembly you can start it to see if it still shakes. JimN
