Posted by jdjack on September 16, 2008 at 21:22:37 from (72.160.207.70):
I replaced the pilot bushing and throw out bearing, bushing fits input shaft good, replaced pressure plate and disc. Adjusted clutch. With tractor running, still grinds when installing into gear. With clutch pedal pressed can see input shaft spinning very slowly, with pto engaged, it will not spin. It has a slight drag on it somewhere. Clutch is adjusted correctly, disc floats good. Is there a coupler in the input shaft on these? I don"t have a parts diagram of transmission or input shaft. Any more ideas?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
