Re: Hubby opened up the F-20 today this is what we found.
Posted by Bob Kerr on September 17, 2008 at 06:35:03 from (63.134.174.182):
In Reply to: Hubby opened up the F-20 today this is what we found. posted by Marjorie Van Fossen on September 15, 2008 at 15:28:52:
Don't use emery cloth. it is WAY too course. Use what is called crocus cloth in a long strip and about as wide as the journal. Pull all the spark plugs out and have someone crank the engine over while the crocus cloth is pulled over the journal to be cleaned. I hold the ends of the strip together with two fingers and gently pull straight down and evenly while the engine turns. If you dont turn the crank and just run the strip back and forth you can get the crank out of round! you don't want to remove a lot of metal, you just want to polish off any rough or "high" spots. Get the crocus cloth from NAPA.
