Re: IH 806 pto clutch adjustment
Posted by Ed pap on September 17, 2008 at 07:37:27 from (74.33.241.245):
In Reply to: IH 806 pto clutch adjustment posted by Dave Hundeby on September 16, 2008 at 22:11:30:
Hello Dave,
There is no adjustment to take up the wear. That PTO is hyd engaged clutch packs. the only adjustment is on the lincage. you will need a 300psi gauge to check hyd pressure it should have 175-185psi. the test port is on the side under the spool. If the pto is slipping and you have pressure the clutches are bad. I just did one yesterday the rebuild kit is $115.00
Good luck Ed
