Re: Engine doesn't fire when starter engaged
Posted by RustyFarmall on September 17, 2008 at 09:00:51 from (209.152.78.71):
In Reply to: Re: Engine doesn't fire when starter engaged posted by nosoup4u on September 17, 2008 at 07:51:57:
I'm thinking that there should be a connection that supplies a full 12 volts to the ignition when the switch is in the "start" position, and then after the engine starts, and the switch is returned to the "run" position, only 6 volts is supplied to the ignition. You are either missing one of those connections, or the switch has gone bad.
