Re: no power?
Posted by Brownie 450 on September 17, 2008 at 17:14:07 from (216.51.158.151):
In Reply to: no power? posted by mr77fm on September 17, 2008 at 14:38:57:
Check ignition parts first--points, plugs, rotor& cap.
I'm with Del & EM on fuel starvation. We had to set our SC's float 3 times to get it right. When it won't pull, it most likely is float level too low. Do things improve if you pull the choke out??
Just an outside chance that the valves need gapped???
