Re: Engine doesn't fire when starter engaged
Posted by 47M on September 17, 2008 at 17:36:01 from (75.163.73.150):
In Reply to: Engine doesn't fire when starter engaged posted by nosoup4u on September 17, 2008 at 06:39:36:
I had the exact same problem on my old Harley Sportster a year ago. When I'd push the start button, it would crank and crank and crank but wouldn"t start until I let go of the starter button.
My problem turned out to be corrosion inside the plastic sheath of one of the battery cables. Of course, I didn't find the problem until after I bought a new battery and started to replace it. The bad cable was apparently passing enough current to turn the engine over, but dropping enough voltage to not fire the plugs.
(Something else to check in case you find your wiring is correct.)
Mitch
