Re: H and M parts interchange
Posted by Andrew Kappers on September 17, 2008 at 18:06:35 from (207.118.208.58):
In Reply to: H and M parts interchange posted by lust for rust on September 16, 2008 at 19:44:47:
You should be able to find one in a salvage yard pretty cheap. Should be under a couple hundred bucks if not that.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
