Re: Super C Oil Capacity
Posted by rustcollector on September 18, 2008 at 08:03:14 from (130.18.53.203):
In Reply to: Super C Oil Capacity posted by Greg WRK on September 18, 2008 at 06:59:59:
Greg,
Start with five quarts and check the lower and upper gauge ports. If oil level is to the top, start the tractor and run for a few minutes and check again. If not to the lower gauge port, add 1 quart and check until you get oil out of the ports. You may need to check to be sure the ports are open and not clogged with dirt. May need to add another quart once tractor has been run and filter is full.
