Re: Get the rod out?
Posted by 510 plows on September 18, 2008 at 10:35:00 from (134.29.140.76):
In Reply to: Re: Get the rod out? posted by Mac DeBusk on September 16, 2008 at 15:08:37:
Pulling the TA lever back will release the TA clutch if the linkage is adjusted correctly. The sprag is inside the TA unit and it's job is to prevent the TA unit from turning backwards. Pushing the clutch down will also work, but here again the linkage needs to adjusted correctly. A lot of people know that when shifting the tractor out of gear when stopping when going up a slight hill the shift lever is diffucult to get out of get because the clutch is not releaseing the TA clutch but pulling the TA lever back the unit shifts fine. Hope this helps
