Well, if I have to rebuild a W6 anyhow...
Posted by Crazy Red Power in SE-WI on September 18, 2008 at 11:13:55 from (68.114.236.202):
...how much piston do I have to put into this machine to get 40-45hp on the belt? I'm thinking 400 or 450 pistons might do the trick. However, I don't want to tear up the rear end, over heat the engine & make sure the engine is getting plenty of mix. Will the W6 pull a 4 bottom plow & not suffer the same problems that plagued the 560? I guess I'm not too concerned about the plow. But, I need the most out of my pulley. Any suggestions about piston, carb size & anything else I might need for the project would be appreciated. Thanks - Mike
