H tranny leaking
Posted by GordoSD on September 18, 2008 at 11:19:26 from (66.115.200.140):
Took the H out for a shakedown cruise this morning. That new engine with the $400 head, goofy firecrater pistons, just purrs and roars like it should. Just a hint of blue smoke that should disappear when the rings and new sleeves get acquainted.
I have a substantial leak coming out the access hole in the bottom of the tractor. Removed the coupling shaft for the belly pump. Looks like a seal at that forward end of the drive shaft. Behind the flange and in the retainer.
It'd pretty close quarters in there. Can I change that seal (p/n 79634H) working through the access panel hole?
Gordo
