Re: B Farmall will not throttle
Posted by garytomaszewski on September 18, 2008 at 18:42:08 from (4.158.174.227):
In Reply to: B Farmall will not throttle posted by thumbanger on September 18, 2008 at 17:36:50:
How can you tell it works when not running??
Are all the connections tight and properly adjusted???
Does the govenor shut you back down, when you operate at the carb??
What does the manual say about adjustments??
You do have an operators manual, don't you??
