Posted by kippster on September 19, 2008 at 11:14:39 from (24.144.197.139):
In Reply to: Re: H MAINTANCE posted by RANDY DAUGHERTY on September 19, 2008 at 06:29:39:
I have a 48 h and all I use in the tranny/rear end is 80/90 wt gear oil. It is put in through the big plug in the platform just behind the steering post. As for the hydraulics, they use engine oil. I usually use straight 40 wt in mine. the fill tube is about 1 inch in diameter and is under the gas tank on the ignition/spark plug side of the tractor. Should be a dipstick in there once you get the little cap off. It was mentioned before about the engine oil and using 15w40. I wouldn't do that if I were you. Those engines were made before the invention of multi-viscosity oil. They were designed to run with straight 30 weight oil. I use striaght 40 weight in mine. Hope that I was of some help and clarification for you. An H is a great tractor. Enjoy yours and have fun.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
