Re: SM w/loaded tires
Posted by rustred on September 19, 2008 at 15:36:26 from (209.115.232.65):
In Reply to: SM w/loaded tires posted by kopeck on September 19, 2008 at 15:12:16:
didnt say what you had for trailer. simplist thing to do is load it on trailer with 2- 7000lb. axles, which is lots of trailer for that and giver.time is money, by the time you fooled with fluid you would have it home.you wouldnt notice much diff in fuel, fluid or no fluid. you might find out you need the fluid if you put it to work.
