Re: SM w/loaded tires
Posted by glennster on September 19, 2008 at 15:43:21 from (68.60.242.156):
In Reply to: SM w/loaded tires posted by kopeck on September 19, 2008 at 15:12:16:
with a 13.6X 38 tire, using 5 lb per gallon of chloride, you would have 614 lbs per tire, so you got a good half a ton of ballast in the tires. if you got a good solid trailer, you are prolly looking at 6500 to 7000 lbs for the super, loaded tires, one set of weights, with all lube oils and fuel. i think the super m weighs around 5500 bare.
