Re: SM w/loaded tires
Posted by tim cota on September 19, 2008 at 19:06:39 from (205.188.116.73):
In Reply to: SM w/loaded tires posted by kopeck on September 19, 2008 at 15:12:16:
I have a super m 6495 lbs loaded tires 1 set of rear wheel wieghts if possible leave the fluid in the tires it will pull or work a lot better these tractors seem to need the wieght to realy take a good bite hope this helps Tim
