Re: SM w/loaded tires
Posted by mkirsch on September 20, 2008 at 15:53:13 from (67.240.251.254):
In Reply to: SM w/loaded tires posted by kopeck on September 20, 2008 at 14:32:48:
If you've only got 5 lug nuts per tire, that trailer won't have any tires left by the time you get it home, if you get it home.
Minimum I'd haul it with is a trailer that had 6 lug nuts per tire. That's a 10,000lb rated trailer, which will weigh approximately 3000lbs by itself. The M will weigh 6500 with tires loaded, so the trailer will be maxxed out, but it will haul it.
Is that 80" between the fenders? That is the important dimension here, BETWEEN the fenders. The tractor has to squeeze through.
