Re: Re: cast iron vs alum. pistons,which is best
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by john d on March 23, 2000 at 16:14:44 from (206.141.74.34):
In Reply to: Re: cast iron vs alum. pistons,which is best posted by Kendall on March 23, 2000 at 14:34:14:
At the speeds these things typically run, I wouldn't think you'd need to re-balance anything. Maybe if you had aluminum pistons as original equipment, and then went to cast iron, there would be some cause for concern. When replacing cast iron with aluminum, I'd think the strain on the rods would be a LOT less, and any extra weight on the crank wouldn't be enough to shake things.
Maybe some of you pullers out there could shed some light on how many rpms these things have to turn before balance is a critical factor?
Post A Followup
: Re: Re: Re: cast iron vs alum. pistons,which is best
