Re: Farmall 100 - s/n on engine block
Posted by Hugh MacKay on September 20, 2008 at 16:39:14 from (209.226.247.66):
In Reply to: Farmall 100 - s/n on engine block posted by couv on September 20, 2008 at 07:28:40:
couv: If the block part number is 354898 R3 a 130 rebuild kit will not fit. 130 has block number 366204 R1 and that kit will not fit block 354898 R1, R2 or R3. Either someone is pulling your leg or you had a parts guy that didn't know much more about it than you do. The 354898 R1, R2 and R3 were used in SA, SC, SA1, 100 and 200. There was 3" bore, 3-1/8" bore and 3-1/4" bore kits for that block, and I suspect if it was that much power over your cousins SA plowing the 100 had 3-1/4" bore and SA had 3" bore. You will not get that much different between factory SA and a factory 100.
Block number 366204 R1 can only be equipped with 3-1/8" bore kit.
