Re: F-20 opinions please
Posted by Janicholson on September 20, 2008 at 18:19:36 from (66.173.50.47):
In Reply to: F-20 opinions please posted by Centrall Illinois on September 20, 2008 at 14:26:52:
I believe you have made a good effort. If you have covered the carb intake, with your hand, it should suck so hard it makes you pull your hand off the intake quickly. You may be able to see (muffler off) down in the manifold, It does not take much of a crack to be un-startable. If in doubt, take the manifold off, lay it on its back with the ports facing up, plug up the exhaust port with a rubber ball, and fill the exhaust ports with water. If it comes out the intake, there is the problem.
