Re: Early M runs hot
Posted by Janicholson on September 20, 2008 at 18:28:53 from (66.173.50.47):
In Reply to: Early M runs hot posted by Chris Klein on September 20, 2008 at 18:12:56:
If your stop leak fixed the coolant in the oil issue (I believe in using it as needed, Subaru and others use it as normal policy at all times in some models), then there may be other problems.
The radiator may be plugged up and not flowing. The thermostat could be stuck shut (the thermostat housing has such a large bypass port that they stay cool with a stuck shut thermostat unless worked pretty hard.
The block could have scale and rust in the block's water jacket.
The water pump impeller could be loose on its shaft.
A hose could be internally broken and flapped out into the flow of fluid causing restriction.
The timing could be retarded. It could also be advanced (probably not if it starts well)
Just some thoughts, JimN
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
