Re: farmall front alxes
Posted by Armand Tatro on September 20, 2008 at 19:24:51 from (98.227.135.78):
In Reply to: farmall front alxes posted by SRD on September 20, 2008 at 05:19:52:
For added safety I would bolt on the front support from a tractor spliting set to the frame rails to increase safty. That should make the tractor very stable while changing front axel. Armand
