Re: Farmall B Motor ?s
Posted by Janicholson on September 21, 2008 at 16:59:24 from (66.173.50.157):
In Reply to: Farmall B Motor ?s posted by Zach Bouchard on September 21, 2008 at 16:32:35:
Bs never had hydro, so if it has a plate below the governor, it has a non stock engine. The engine should have a C123 cast into the area near the oil filter. If it does not, it could be a 113 cid from a super A or C all of which (to my recollection had hydro. Hydro can sure be installed if it has the blockout plate. The hydro tank will not fit under the gas tank on some models, but a seperate reservoir, and valving for an open center system is fine. JimN
