Re: Stuck 22-36
Posted by El Toro on September 22, 2008 at 04:25:00 from (205.188.116.73):
In Reply to: Re: Stuck 22-36 posted by spiffy1 on September 21, 2008 at 19:04:04:
Use the ATF and let it soak. You may need to pull the head and pan and pour some diesel or kerosene in one cylinder at a time and set it on fire then see if you can drive out the piston and rod. Hal
