Re: Super M Torque Amplifier: will tractor still functio...
Posted by Wayne from MN on September 22, 2008 at 08:54:33 from (66.228.243.49):
In Reply to: Super M Torque Amplifier: will tractor still function if... posted by DennisT on September 22, 2008 at 08:01:39:
My father-in-law used his SM-TA for years with the TA non-functional. The result was you had just the regular transmission ratios to use like an M or SM without the TA.
Replacing or rebuilding may get into the $800+ range depending on what is needed. My sons & I tore the TA apart & determined it was worn to the point it was more ecomical to replace.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
